VJ 1604 Life Times [Pnmp]
randya
It will continue to work fine until the pump fails.
Could be a long time, could be short.
It has just counted the number of cycles that the pump has been activated and reached the number that is in line with MFBF (mean times between failures) analysis.
You can call your dealer and they will walk you through resetting the timer to shut off the message.
You probably should start thinking about a new pump, though.
henryp
I was wondering if anyone found out how to clear the lifetimes counter?
Switch off the printer. Simultaneously press and hold down the Left Arrow key [< ], Right Arrow Key [>] , and the Down key [-], switch on the printer. Keep pressing these 3 buttons until Maintenance Menu is displayed on the Control Panel.
