FaneDuru
We use such a machine since 2011 and it worked well. Last year we faced a problem regarding black side of the head and it was obviously for everybody that the had is gone. But I found a way to transform any CMYK layout in CMY, using a specific color profile and the layout transformation is not visible for anybody. So even using a little more ink we could print well using this workaround and the old head...
Now I am facing the next problem: The Magenta side started to behave strange. I mean there are the next thinks looking strange:
1. After a good cleaning it works well. Printing let's say 1 meter length (about 1 meter width) it works perfect. After stopping the machine if I start it again with the same layout it prints wrong... Like some vacuum is created during printing and stopping the machine air is absorbed into the printing head.
2. If I start printing three such layouts it may be working well or at the end Magenta ink starts to diminish.
About two weeks before Magenta ink tank has not been filled on time (bulk ink system) and some air went into the printer sub-tank. I knew that small air quantity is not so dangerous and I printed well for a while. Now I remember that story and I thought that maybe that air can explain the above described behavior and I proposed myself to extract it. So, with printing machine Off I took out the Magenta damper and using a syringe and a Y tube I extracted all magenta ink and finally some air appeared.
But keeping air sucking a kind of vacuum has been created and removing the syringe even more air went inside the pipes... Ideal would be to open that specific sub-tank valve in that moment of having the syringe creating vacuum, in order to absorb all the air on the pipes, but HOW TO DO THAT? If I try the above described operation with machine powered On, when its sub-tank will be emptied the valve is automatically open and the air still remains on top of the ink. I need to open it only when the sub-tank is fully emptied. If I would try to power On the machine it will try to move the carriage to the cleaning station...
Is there a workaround or another idea to be used in such a situation?
Thanks in advance!
Thanks in advance!
