VJ1204 NO ink
Curt Bullick
We just installed a new print head, MS, and bladders. Fired up machine and ran a strong clean and wouldn't pull ink thru. I removed the bladders and pulled ink through them and tried it again. Still no ink is pulled through the lines during a clean. We thought well maybe try to print and see what happens, still nothing
Any help, ideas? Please and Thank you.
RG
Look closely to see if the print head is parallel to the platen. It has to be parallel in order to fit properly on the MS. Have you tried the "Little Charge" function? Check to see if there is a blown head fuse on the main board.
