CP Signs
Hello. Having a little issue. Changed the maintenance station 2 weeks ago ( second one in 6 years, not bad ), printer worked great for the 2 weeks. Yesterday, went to print and barely had color down on media. So no problem I thought, seen it before... took the capping off, cleaned all the tubes, removed the gooey in the lines. Put it back together and went to do a cleaning and that's when I notice no ink was being sucked in the tubes down to waste tank. I put cleaning solution on the cap and the solution comes down the tubes. So I tried to take it apart again and put it back in case it wasn't sitting properly and not creating a suction. Did another cleaning and no inks down the tubes. I've read tons of posts here and some mention the F2 fuse? If so, where is the main board located? I've done maintenance on this machine for 6 years but never was in this situation. Thanks for any help
