Wall graphic media
Pinfinity
Can anyone recommend what digital media would be best suited for an interior latex painted wall?
The overall finished size of the graphic will be 24" x 40'-0". Also, since the wall is finished with latex, I there ay barrier coat prepping or primer needed to apply..such as bin 123 or?
Any help would be greatly appreciated
JBusch260
Permanent or temporary?
Always had good results from 3M Textured Surface vinyl (IJ8624) for a permanent install. Use post heat!
If temporary, photo-tex works pretty well also.
Pinfinity
One question, what is considered temporary? This is for a realty Probably up for at last one year. I'm using solvent printer.
Do need wall prep for latex covered walls?
C
ColoPrinthead
Guest
I like Avery 2611, I was able to cleanly remove one graphic after being up for 9 months. I have IJ40 on a wall now but haven't had to take it off yet.
Phototex is great stuff also.
d fleming
Have an interior mural up for three years now on latex painted wall in phototex printed full solvent. Still looks great. Can be removed if needed easily.
