custom sign center
Well this is a new issue for me.
I usually use PDF files with a cut path in Wasatch (I run Wasatch 6.3) and have no problems. I sent a small print file as an EPS with a cut path, printed it and it never put the file in the cut queue. I sent the same file as a PDF with the exact cut path and in dropped into the cut queue no problem. I started experimenting and same thing.
If I send an EPS cut only file without printing the EPS works fine.
Any ideas?
Any ideas?
