Wasatch printer/cutter question
heyskull
We are running our valuejet 1604 as the printer and it has a mutoh sc 1400d plotter for cutting.
We have started making a lot of MotoX graphics but the plotter is struggling with the material.
Could I use my old Graphtec Signjet Pro2 as the plotter as this cuts a lot harder and it is more than up to cutting it.
The question is how do i set it all up in Wasatch?
SC
FatCat
Looks like the Signjet JX-2000 is supported, not sure if that will work for the Pro2.
http://www.wasatch.com/cutterlist.html
Does the Pro2 have an optical eye/reader? If not, it probably won't work.
*Setting up automatic contour cutting or importing a cut path is a breeze in Wasatch Softrip. You print the file with registration marks, or using the cutpath you created and load your material in the cutter and Wasatch does the rest. I use it all the time with my Summa and it is very easy and very accurate.
heyskull
Yes my signjet is a jx2000 but it doesn't come up on my list.
It does have an optical eye to read reg marks so it should work.
Guess I will have to contact wasatch.
SC
FatCat
For kicks, I just opened Wasatch and looked under my profiles and that cutter is not showing in mine either...I am running 6.6 which is the newest version.
Says it is supported on their site, but neither of us have it in the profiles.
Need to give them a call.
heyskull
Well i've called them.
Can you believe it but I have to upgrade!
There's a supprise...lol
$700 just to add a plotter I don't think so!!!
I have wrote my own drivers in Signlab so I may give this a go.
SC
