What is causing this?
busypc
Okay, i've changed out the maintenance station and installed new dampers. All of the dampers are holding ink except one. But, when i pulled the ink into the yellow the yellow appeared. When i did a test print a while later i glanced at it and the yellow inside the damper was not yellow...it was a dark blueish color. What can cause this?
