Carolina Girl
Hello all, having print problem with my Mutoh VJ1204 recently and here's the run down.
1. Stopped printing blue at first.
2. ran head wash, replaced all dampers, inks running through lines fine.
3. did a slight pressure test through the print head and all inks are going through.
4. flushed pump lines, all drain lines are clear.
5. Replaced cap in MS. Am able to pull ink through drain line from print head
6. Ran several heavy cleanings, now nothing is printing.
Thanks much for any advice to resolve this issue.
CG
CG
