What step am i missing? (warp object issue))
rawjahprintshop
Hey guys, What am i missing here? Ill go ahead and upload an image, but I am running into a step i must be missing. Im newer to illustrator, i originally designed and learned from Gerber Omega so im having to go the hard route unlearning that and relearning illustrator! you will see a picture of the exact example, where the "selected" outline is actually the same line as where the "roland cutline " is also appearing.
Didnt hit print yet to see what it would do, but wanted to get your guys opinion, since i feel like this is another type of issue to learn like i learned when setting a entire new layer for cutting , especially when using compount paths and clipping masks.
thank you in advance boys and girls.
DARRELL OAKS
Another thought, in illustrator put the roland cut lines on a different layer - have it the top layer in the file. With versaworks you only need one and you can step it off instead of trying to do so many from illustrator, might give it a try.
rawjahprintshop
Yes, i agree. again still learning compound paths for clean artwork at the end, and THEN also, I select cut line, (might have a fill still at this point) select, Same Stroke Color, Copy/paste on top with, Disable Fill, on the top layer.
that's what I've learned. so far. still need to find more seemless ways...
