Adam Vreeke
Knows just enough to get in a lot of trouble..
I have been running a JFX200-2513 for about 7 years now with Rasterlink 6. We use A LOT of white ink here and do a fair amount of backlit work. When I print white on the base model when printing CMYK and White, there is a gradual gradient buildup of white when laying down. We liked this machine because of that and it helped reduce the lawnmowing effect that you get with some machines.
Since we had great success with the baseline machine and we are getting more work, we added in a JFX200-2513EX right next to the normal machine (just had it setup about 2 days ago). This is where my problems started. When printing white ink, it does not have that gradual gradient buildup of white when laying down. it puts it down in strips and has the lawnmowing effect, as well as very weird finished pattern on it.
I have played with different icc profiles, played with all the MAPS2 patterns and smoothing levels, halftone level options in quality tab of RL and nothing seems to fix it. I looked at some online videos of white printing and saw they had the gradient printing. I have a feeling there is an easy solution to this that I am just missing. I have attached some pictures for reference.
We also had to switch up to Rasterlink 7 instead of 6 so I can run both machines. Now when I print to the old machine via RL7 it will print the white with the same old white gradient, so I know I have a machine setting to deal with.
Any help is appreciated, thanks!
