I have a cheapo UV flatbed printer that is based on the Epson 7880 and the DX5 printhead. CMYK+WWWW. I have had good success but this always comes with hours of frustration. Many issues, and most of them stem from the UV white ink.
If you know the 7880, it has the 4 ink cartridges on the left and 4 on the right. My machine has 8 bottles of ink with a ink line to each (4 lines to a larger white bottle). There are no fancy seals on these bottles so one question that has bothered me was "how are these bottles different from the ink cartridge in terms of ink delivery?". If the printer is left idle for 2 hours, I need to reprime the print head. I do this by sucking a bunch of ink through the print head. How? I hook up a vacuum pump to the waste line and pull 20in Hg for about 60 seconds. This wastes about 30-50ml of ink. I actually installed a valve on each line so that I can shut off ink lines if one channel is bad to save ink.
I can't figure out why I need to do this? I really don't think the ink dries and clogges the print head. My best guess is ink is draining away from the print head back into the bottle. This is actually why I installed the valves in the first place; however, I don't notice much difference when I shut off all the lines after using the printer and then coming back to it after a few hours. I still have to prime it. And it does it to the color just as easily as the white inks. The bottles are just slightly lower than the print head. I was wondering if I raised them to be 12in above the print head if ink would drain (siphon) out of the print head? Or does the print head nozzles seal off when not powered?
there is a lot more to this but I think I will just stop here and see if anyone has any input on this particular issue.
thank you in advance for your input.
