Went to print this morning and my yellow quit printing about one inch into the print. Now the test only has intermittent yellow (a couple lines maybe). The damper is full, so it seems my problem is between the damper and the head. Kinda like it is not getting ink to the head or it is not firing the yellow. I am kinda leaning toward a problem with the damper/head connection and thinking that the inch or so I got this morning may have been in the head when I went to print. If it were a fuse or board issue, I would think I would get no colors at all, but magenta and cyan are fine. One thing I did notice was that the last dampers I got do not fit very tight on the head, at least not as tight as the ones before did. I wonder if I have the wrong size dampers and it is not sealing good. Anyone got any thoughts?
