Terms and Conditions:
General Disclaimer
All products are warranted by the respective product's manufacturer. Copies of such warranties are available upon written request.
Installations
You, the customer, agree to provide the vehicle(s) prior to installation conforming to the outline preparation guides provided by {{company name}}. If it is necessary for {{company name}} or it's contracted installers to wash or prep vehicles prior to installation, additional charges may apply.
Vinyl Graphics for vehicles are designed to be viewed from 6 ft. or more. Wraps viewed from a lesser distance may have minor imperfections. Small imperfections such as bubbles, cuts, dust spots, and tears less than 1/2 inch are normal and may occur over the life of the vinyl graphic. Seams and areas of overlaps are a natural occurrence with vehicle vinyl graphics, however, {{company name}} will work to eliminate them or minimize seams and overlaps as much as possible.
Because a two-dimensional print is being applied to a three-dimensional vehicle, and due to minor variances in the accuracy of the templates, the positioning of a vehicle wrap can vary from the proof. This is normal and wraps need to be designed with this in mind. If an artwork proof is provided, it is provided for visual purposes only and is used to give clients a general perspective of the graphic concept.
The wrapping material that is used for vehicle wraps, does not stick very well to plastic or rubber parts such as window trims, side plastic moldings and plastic door handles. It is advised that these areas NOT be wrapped with adhesive vinyl. Initially, the vinyl will stick, but over a short period of time such as a few months, the vinyl will fall off these areas.
During the application of the vehicle wrap, {{company name}} installers may need to remove exterior trim and emblems.
You, the customer acknowledges that you have been informed that the removal of vinyl wraps will occasionally cause the flaking or damage of paint on older, rusted, damaged, or repainted (non-factory) or fiberglass vehicle bodies.
Off-Site Installations
If an installer contracted by {{company name}} is coming to you, the customer's location, you, the customer agrees to provide a clean space of sufficient size that is temperature-controlled, heated and air-conditioned with adequate lighting.
You, the customer agrees to pay $120.00 USD charge plus actual travel expenses if you do not present your vehicle(s) for installation at the scheduled location, on the scheduled date and time or if cancelled less than 24 hours before said scheduled date and time.
Third-Party Installations
{{company name}} does not warranty, accept responsibility or any liability for graphic failure resulting from improper installation methods, when graphics are installed by an application that is not contracted directly by {{company name}}. You, the customer agrees to hold {{company name}} harmless for any damages resulting from vinyl wrap installations performed by someone other than {{company name}} or its contractors.
Any referral or recommendation of an application company offered by any {{company name}} representative does not constitute any responsibility or liability on the part of {{company name}}.
