PA WTB HP Latex 365 Color Sensor
lvking
Looking for a color sensor B4H70-67106 for my HP Latex 365. Want to make sure it is the problem before I spend $$$ on a brand new one.
ToTo
Professional Support
Depends on the issue. 99% of replacement are caused by broken mechanical parts. Mostly the handle breaks and the spectro can’t be opened.
Several other cases are caused by malfunction of the opening mechanism located on left side just beside the printbed. It’s a plastic engager driven by a solenoid. And this plastic can be bent.
Can you see the light from spectro while reading?
lvking
Yes I can see it and everything works correctly however the little arms that hold the sensor to the carriage are broken and it allows it to move as the carriage whips back and forth. If I could make a new cover the problem would be solved. I currently have glued tiny washers onto the sensor housing to hold it in place and its working but I would like to have a spare.
