Click to Support Signs101 ...
i'm tryin to print banner and yellow background but when i start printing the yellow becomes yellow green. i already clean the heads. what should i do next.. please help i'm using soljet pro ii v 545ex.
is your nozzle check green where is should be yellow?. if not then its something the RIP is doing.. like above make sure you are in CMYK, and if your RIP allows, use the colour replace option to select the background and change it to 100% yella..
