Don't worry, we have the same vice/problem..
![Biglaugh :big laugh: :big laugh:](https://signs101.com/images/smilies-orig/standard/biglaugh.gif)
However I bought a
PCI card with a
25pin connection and 2 cables, one
25 -> 25pin and the other from
25 to 36, for the parallel.
The old owner claims that only one of the 2 cables needs to be connected, can you confirm this?
In case anyone is interested, I installed the device as a printer, as suggested in the drivers readme and now it is correctly installed.
As for software I'm trying
Cutting Master v2.00, but this doesn't seem to allow the selection of one of the printers, it only allows you to select the plotter from the list provided, I select
CE3000 and
COM1, but it doesn't work, obviously I also tried to change the port , without success.
I don't know if there is any software that allows you to rely directly on the devices installed in the system, for example I would have liked to see if it's on
SignBlazer, but I can't find it online anymore..!
I also have an old version of
FlexiSign, 8.1, which has the
CE2000 in the list, with this program, by sending a test cut on
COM1, it is eliminated from the list of pending prints (on
Production Manager), but the
Cutting progress is not seen from
0% and the plotter does not move.
