Dyss cutter control panel troubles, In need of some help
StandoutGraphics
Hi there,
I have come in to start the day's work and our Dyss x7 super head has started up fine on the computer, but has failed as far as the control panel is concerned, the reason being is that when starting up there is a power switch on the side of the machine, that you switch on that links the computer to the cutter bed/head, this works fine however there is a secondary link on the control panel which is labelled an on button that for some reason will not function, I have tried a regular shut down, restart and a hard shut down although all of this has failed, if anyone could help me out with this it would be much appreciated!
p.s. I have added a photo to show the style of the control panel if it helps in any way.
Regards,
Clarence Chaplin
  • cutter panel.pdf
StandoutGraphics
Its all sorted now, the problem lied with the pressure supplied to the machine, we found that the compressor had failed and wasn't supplying a sufficient amount of air, we fixed the compressor and then continued to run the machine without any issues.
