Free Stuff For Y'all
jfiscus
Rap Master
2015 ez go rxv
Here is a template I made a couple weeks ago for an EZ GO RXV golf cart.
It should work well for you, but I do NOT recommend wrapping the roofs of these due to the insane recesses.
  • Golf Cart Panels.pdf
jfiscus
Rap Master
Motor Coach
Attached is a motor coach I just set up from scratch. It should have a (PVO) freightliner cab on it, but that was not my artwork so I removed it before saving a copy for everyone here. Enjoy! Set up at 10 percent scale.
  • Coach Template 10-percent blank.pdf
myront
CorelDRAW is best
Here is a simple 12"x18" pole sign mock-up template.
I've done much of the same sign templates and assigned a macro to the most common. Aluminum sign blanks from most third party companies use a corner radius of 1.5" with 3/8" holes centered 3" from top and bottom.
We don't use vehicle templates for wraps. Way too many variations within models. Easy enough to photograph and scale to full size.
SightLine
All of this comes in handy. Thanks! I'll pitch in too. Couple of different size Knapheide KUV service bodies at quarter scale. Because these come in so many different configurations and sizes you should of course verify the dimensions and stick the chassis front you need on them. I've had these with pickup cabs, van cutaways, and even a new Transit cutaway cab.
  • KUV25percent.pdf
jfiscus
Rap Master
Thanks, I actually had one of these on my "to draw" list. I'll just go off my measurements and adjust to fit his truck.
jfiscus
Rap Master
Spartan Service Body for Ford Econoline cutaway chassis.
Artwork at 1/20 scale.
  • Ford Econoline Spartan Service Body.pdf
jfiscus
Rap Master
MRAP Scale Template for Vehicle Graphics
NOTE: The front hood/grill/fender area may not be correct, I didn't measure it that well as nothing was going on it, but everything else SHOULD be pretty close. Also, there are a LOT of different configurations of these, so measure your vehicle and compare to the template!
Set up at 1/10 Scale. ENJOY!
  • MRAP.pdf
jfiscus
Rap Master
The template worked out great for me on this project, btw.
b2413
Great Work
Jfiscus you have to put together a tutorial of how you are doing this. Very helpful! Thank you!
jfiscus
Rap Master
Hubcaps
Something from like 2009, but someone might find it useful? Various hubcaps for RC cars.
  • Hubcaps.pdf
