Living Wall Sign?
jfiscus
Rap Master
This will be a first for me so I'm coming to all of you to hopefully answer an issue before it ever arises. We are doing studded dimensional letters protruding about 6" off of a living wall. This will be in an (interior) office space, but my concern is about humidity/moss/mold potential issues.
They'd like their logo/lettering cut out of a white material, so if there is a potential for it to start to turn green in the future I'd like to avoid that.
Are there any thoughts on any materials that might be better to use for this project? What ones to avoid?
I'm going there tomorrow to do a site survey to determine the best mounting procedure. Should be a fun project! Photo of the actual wall attached.
Bradley Signs
Bradley Signs
WOW! That looks like a place in Fort Worth area I was at a number of years ago....
Unless they don't have A/C or some sort of air movement equipment, cant see a problem myself. Aluminum doesn't rust, and anything with paint will attract mildew, unless the air is kept moving.
Are the plants watered mechanically? Will water be able to sit on top the letters or inside the cutouts?
There is some maintenance to this type of thing, and I can't imagine that place not having a cleaning crew.
Would seem to me, as long as the parts are rust proof, stainless or aluminum, Seems like a cool project.
I hope you post some pics when it's done.
treat it like an exterior sign, and you should be fine. mold/corrosion is a living thing too, but highly unlikely that will even be a factor unless you're making it out of paper-mache
Tessellate
We have done something like this before. We have a 150w laser in house so we reverse cut 1/2” white acrylic and mark the locations for pins.
Recently did a wall wrap there and they still look brand new. As mentioned they will require some cleaning here and there from water spots but the cast acrylic is rock solid.
Brando
I’d probably go with white acrylic. But I think you’ll have trouble taping up a pattern for installation.
jfiscus
Rap Master
Not the best photos, but everything turned out awesome. We pin mounted the letters and welded the pins to rails (painted black). Hung the whole thing (around 2 pounds) by thin black wire off of 2 hooks at the top. We added adjustable legs to the back so that we could get it to sit flat with the uneven wall surface.
Stacey K
I like making signs
I love it the concept of this, the sign looks great, good job!!!! Thank you for posting a finished pic!
Bly
Nice. We did some lettering for a pharmacy that was meant to float in front of a bulkhead covered in long moss.
The letters were glued to a clear acrylic panel which dropped into a slot.
Your solution looks really neat.
jfiscus
Rap Master
We're already on to our 2nd living wall sign.
Did a few things differently this time.
Pics below should explain a lot of the process for the curious. ;)
119403493_319474805781168_7907809038903368437_n.jpg 119655670_665043981108505_5439276738817393940_n.jpg 119340575_383301356397432_4026589985697935888_n.jpg 119245757_3126175334158175_6348412964138821590_n.jpg 119244614_1239899916371917_3127987230454865569_n.jpg 119506982_992395557851547_6461328444071530279_n.jpg 119217058_686080055679135_1218248922095326829_n.jpg 119471592_2791556661129355_3382382989448278050_n.jpg 119646863_948333248996560_4511930141088920279_n.jpg
Greg Kelm
www.cheetaprint.com
You should consider a mig or even better, a tig welder with gas shield. Some scrap leather to avoid the splatter on your routed parts is not a bad idea either. The final result looks really nice!
jfiscus
Rap Master
Look at the 2nd image. This is a sacrificial set of letters.
The "real" letters were being painted while the others were attached to the framework getting welded together.
It seems no matter how well you think you cover it up weld spatter finds its way to the letters and discolors or damages them.
Since they're the exact same pattern we just popped the junk ones off and pitched them and painted the frame without worry of over-spray from either color.
After the last coat of paint we will glue them back together for install later this week.
Greg Kelm
www.cheetaprint.com
I see it now. Was thinking that there has to be a better way to avoid all that, but your method make sense now.
jfiscus
Rap Master
I didn't know it was getting installed right under the last one, but it turned out pretty good!
Both of these faces are about 12" in front of the actual "wall" surface.
