Our new sign
TimToad
I know, I know, it should not take a year and a half to make a new sign for yourself, but the procrastination is over.
attachment.php
TimToad
Looks sharp! What standoffs did you use that will hold up outdoors?
Thanks.
We just used some MBS aluminum ones that I shot with some matte clearcoat. Out here in Cali, it never freezes, snows, etc. They should be fine for a few years. We used some additional blocks with VHB tape behind the second panel so it laid nice and even without adding too many other visible fasteners.
I cut my teeth as a walldog back in the early 80's in Chitown. I went to Washburne Trade school for four years through the sign and pictorial painters union back when it still was open. You are in a great signmaking town.
Have a great holiday. Go Bears!
JERHEMI
My father went to Washburne Trade School as well! I think he went for machining, but he is a jack of all trades! I hear a lot of people who say that school should have stayed open because their isn't any sort of school like it around anymore that teaches the trades.
Thanks.
So, what materials and time went into it ?? Any neat procedures or gimmicks, needed ??
copythat
2 Thumbs Up!
Sign looks Bad ( Y ) When it comes to doing work for ourselves we are the biggest critics. Took over 30 images and many change overs on the wording. Kust to do our own wallscape. You did and great job.
Sign Up!
TimToad
Very nice. :thumb::thumb:
I would also like to know about the materials/methods used. Definitely a nice clean finished product.
Hope you all had a relaxing and safe holiday.
Thanks for all the kudos. We think it reflects the company's image well and projects the kind of work we do now and aspire to continue doing into the future.
Nothing all that out of the ordinary as far as materials and technique, but it did create some nice depth and the clean, modern, concise lines we were seeking. The primary backing panel is a 2" deep .063 aluminum panface. I really like this approach for a couple of reasons. You can create any depth sign you like without having to build up solid materials. Its easy to put up and there are no visible fasteners on the face of your sign. The MBS standoffs we used to adhere the second panel to the black backing panel were a conscious design decision. We could have blind mounted that panel also, but thought the aluminum caps were a nice touch.
The secondary panel is just 3mm DiBond with a matte laminated print mounted to it. The dimensional letters are all routed from 1/2" thick high density PVC and painted with a satin exterior enamel. We mounted the letters with VHB tape and a few dabs of Gorilla Gel Superglue on each letter just for added bond.
For the install, we mounted two 1"x1" x 1/8" wall aluminum square tube to the wall at the top and bottom inside measurements of the black panface length. After sliding the panface onto those, we adhered the sign to the tube with a couple self-tapping screws and called it done. Total install time was under an hour.
Marlene
looks good. only suggestion would have been to make the orange dot thingy smaller so that there was a margin around it. it would have made the stand offs look better on that side of the sign as they conflict with the other dots.
Angela
"I know, I know, it should not take a year and a half to make a new sign for yourself, but the procrastination is over."
Hey like I always tell people, "The cobbler's children go shoeless"
TimToad
The sunrise is a part of our logo and is sized that way on all of our marketing collateral. That secondary panel is 1.25" smaller on each edge than the black backing panel, so there is essentially a 1.25" black border all the way around it. The angle of the photo and lighting that day makes the standoff caps look way brighter than they really are.
