2013 Ford Police Interceptor
zepher
Has anyone done one of these yet? I'm going to be doing one for a department as soon as it comes in (any day now). I wanted to get the graphics printed up and ready before it arrived. I was just needing the actual dimensions of the thing. Their design had been used on Crown Vics for years but this body is a whole lot different on this one. Thanks!
visual800
I go tthe dimensions of the taurus, im about to crank out two for the MPD
door to door is 18" x 72"
front area above grille for decal is 4" x 22"
on the rear there is a space 4.5" x 28" for rear decal
i hope that helps
jfiscus
Rap Master
Jfiscus - How accurate is the template you posted here on 4-19-2012 ?
Run by a dealership & get measurements from a taurus to scale it off of & then it should work well enough if you cannot purchase an actual, already scaled template (like from PVO).
It worked for the graphics I produced using it until I received the template file from PVO in my 2012 update purchase. I am NOT sure this exact file uploaded here is the one that I scaled correctly for output - it's been a while since march!
