$3000 HP L26500 with $2k in Consumables - needs heater service
collapseTonight
The L26500 took our business to the next level and it can do the same for you. We had 2 years of issue free high quality printing for vehicle wraps, banners, magnets, yard signs and more. We embraced the HP latex product so much that we’ve added 2 more of their machines which can handle more production. We would pay to repair this machine, but are currently fine with our 2 machine set up and do not need a third at this time.
This is a used item in good condition. THE PRINTER IS CURRENTLY NON FUNCTIONAL AS IT NEEDS A HEATER REPLACED. I’ve included a copy of the HP quote to service the printer and replace the necessary part. It will cost $3200 for HP to perform the work. Everything else on this machine is good to go, after the service is preformed you will be running awesome prints immediately.
ADDITIONAL MATERIALS
The package includes quite a few consumables - we have over $1500 of extras, and the machine comes loaded with ink - the ink in the machine is at least $600 on its own.
INK IN MACHINE - ALL 6 COLORS OF VARYING LEVELS
NEW INK CARTRIDGES: QTY(6) 1 OF EACH COLOR
NEW PRINTHEADS: QTY(3) 1 OF EACH COLOR
NEW INK MAINTENANCE KIT: QTY(1)
NEW PRINTHEAD CLEANING KIT: QTY(1)
NEW PRINTHEAD CLEANING CONTAINER: QTY(1)
SHIPPING
We will crate the machine for freight and can load on our dock for shipping. Buyer is responsible for freight costs or can pick up locally. We are just outside of Kansas City.
PAYMENT
We accept business checks or certified checks or bank transfer. Please allow 7 days for checks to clear.
Description:
HP Latex 260 Printer 61" - *Formerly HP Designjet L26500 Printer
Introducing the HP Designjet L26500 Differentiate your business & take on a broader range of high-quality outdoor & indoorprint jobs, including soft signage, vehicle wraps, wall coverings / interior decoration and effective double-sided banner printing.
This versatile printer is capable of producing odourless indoor and outdoor work an an extensive range of media types from a multitude of manufacturers - you are not limited by purchasing just HP medias!
Advancements on the previous version Designjet L25500 including Denser Blacks, Glossier output and significantly the abilty to quickly & accurately print doubles sided banners using embedded OMAS and an effective take up reel system. Reducing your cost and Time for double sided applications compared with alternative & older solvent technology.
Thin medias such as textiles can be easilly fed using the included soft media loading accesory and HP media Holder.
Ink is more scratch proof incresing the range of applications and is comparable to the more costly HP Scitex machines - at a fraction of the capital cost.
Achieve better durability than eco-solvent inks on a variety of media. Prints come out dry, enabling faster turnaround times and more accurate unattended, double-sided printing. Attract environmentally conscious customers—with a printing system that helps reduce the impact of printing on the environment.
Media handling
Finished output handling: Roll feed; take-up reel; automatic cutter (for vinyl, paper-based media, backlit polyester film, and thin banners)
Media types: Banners, vinyls, films, textiles/fabrics, papers, wall paper, mesh (liner used with porous media)
Roll external diameter: 18 cm
Media thickness: Up to 0.5 mm
The HP Latex 260 Printer represents the newest in cutting edge printing technology. The Latex 260 Printer is one of the most versatile machines on the market with ability to produce exceptional quality indoor and outdoor prints. The HP Latex 260 Printer is an amazingly flexible machine that allows users to broaden their reach into new markets including soft signage, while improving turnaround time with precise double sided prints that come out of the printer dry.With the HP Latex 260 Printer keep the environment in mind while never compromising the quality or durability of your work.
HP Latex 260 Printer (DesignJet L26500) Features:
• Double-sided printing
• Instant dry prints
• Includes Take-up Reel
• Maximum Roll width 61" - print up to 61" (155 cm) wide
• Maximum Roll Weight - 88lbs (40kg)
• Speed (indoor quality) 97 ft²/hr (9.0 m²/hr)
• Create vehicle graphics, soft signage, interior decor and much more
• Durable outdoor prints that last
• Create indoor graphics without unpleasant or harmful chemical smells (VOCs)
• No expensive ventilation system required with the Latex 260 Printer.
HP Latex 260 Printer (DesignJet L26500) Technical Specifications:
HP Latex 260 Specifications
Model size
61" 1549 mm
Printer Functions
Functions
Print
Print speed
Print speed
22.8 m²/hr (4-pass bidirectional), 16.5 m²/hr (6-pass bidirectional), 10.6 m²/hr (8-pass bidirectional), 9 m²/hr (10-pass bidirectional), 7.6 m²/hr (12-pass bidirectional), 6.3 m²/hr (16-pass bidirectional)
Memory
Memory, standard
512 MB
Hard disk
None
HP Latex Printing
Print technology
HP Thermal Inkjet
Number of print cartridges
6 (1 each cyan, magenta, yellow, black, light cyan, light magenta)
Compatible ink types
HP Latex Inks
Roll maximum output
No physical limit (determined by RIP software or media roll length); recommended up to 30 m
Connectivity, standard
Gigabit Ethernet (1000Base-T)
Paper handling
Media types
Banners, vinyls, films, fabrics, papers, mesh (liner used with porous media)
180 mm
Media thickness
Up to 0.5 mm
Power and operating requirements
Power consumption
4.8 kW maximum (only when warming up), 2.7 kW (active), 95 watts (standby), 50 watts (sleep), 0.4 watts (manual-off)
Operating humidity range
20 to 80% RH (non-condensing)
Operating temperature range
15 to 30ºC
Compatible operating systems
Will depend on selected RIP solution. RIP to be purchased separately, not included.
Dimensions and weight
Minimum dimensions (W x D x H)
2465 x 690 x 1370 mm
Weight
445lbs
