3M Scotchlite Reflective / Diamond Grade questions
Bretbyron
I am working on a quote and have a couple questions about these materials. I have 80 large address signs, flat, on baked enamel. These are for a resort, so they need to last and be quality.
3M:
4090 Diamond Grade 12yr
680-10 Scotchlite 7-9yr
3290 Scotchlite 5-7yr
As far as I can tell, these are all Engineer Grade.
Question 1: Do you need the hot knife type plotter to cut the Diamond Grade?
Question 2: Are there any options that I missed that might be more appropriate/affordable w/o controltac or anything special?
Thanks in advance, Bret
Zendavor Signs
Mmmmm....signs
3M:
First, Diamond Grade is not Engineer Grade, it is Diamond Grade. Very expensive and not sure if you can even die cut it with a plotter.
It is primarily for traffic signs.
Oracal 5700 has a 7-year life. Striving for life expectancy beyond that is pretty futile. For this purpose, that should be plenty durable.
You can cut diamond grade with a graphtec. Takes some time. Run it slow and a brand new 60degree blade.
But why are you cutting the diamond grade. YOu should sheet the blank and reversed cut the scothlite. No reason to cut the diamond grade. Plus diamond grade is prismatic. When you cut the letters out you get open areas on the edges of the letters. These get dirt and stuff in them and then the letters peel off. The diamond grade should be solid sheet with the electorcut over top.
AKwrapguy
We use 3290 for many of our reflective signs and don't have any issues and we have some pretty extreme conditions up here. Are you planing on printing on these? if so the ink will probably fail/fade first.
TXFB.INS
+1
Bretbyron
Thanks to all for your replies.
We are not planning on printing these. I was just looking for the longest lasting reflective. Do you have any experience with the 680-10?
AKwrapguy
I just got done wrapping two ambulances with the 680CR-10. It's also what we use for all of our reflective decals. What would you like to know?
