phototec
This has been discussed before however I just wanted to share how cheap and easy this is to do and it has made a big difference on my printer.
The adhesive strip of water proof daylight LED's are on sale for 50% off at $9.99, it came with the soldered-on connector and the 12V power supply is on sale 37% off for $6.27, and if your total purchase is at least $35 you get FREE shipping. So I ordered some other items I needed for my Harley to get the FREE shipping.
LE Lampux 12V Flexible LED Strip Lights, LED Tape, Daylight White, Waterproof, 300 Units 3528 LEDs, Light Strips, Pack of 16.4ft/5m
http://www.amazon.com/gp/product/B00HSF66JO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
JACKYLED New DC 12V 2A 2.0A Switching Power Supply Adapter For 110V- 240V AC 50/60Hz 2.1mm
http://www.amazon.com/gp/product/B006NTNGN0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
So for the cost of $16.26 I was able to add daylight LED's to my Roland SP-540V, I could never see the printing area very well when it was printing, the print head area was back a ways under the top cover, now the LED's shine brightly all the way across the print carriage area.
The 3M adhesive backed LED strip was 16.4 feet long and I only needed 70" so I have still have over 10' of LED's left over for another project. The way the LED strip is made, you can cut the LED strip anywhere you want between every 3 LED's, and it worked out perfect for my printer to cut it at 70".
I removed the left cover and there is about a 6" wide cavity on the left side of the printer, so I started applying the LED strip from the left side and stuck it to the bottom of the front/top cover (on the back side of the Roland logo), that way the light shines more towards the back. The pigtail connector goes into the cavity area and that's were I connected it to the mating connector of the power supply (wall-wart).
There are two round holes in the metal panel, right behind the left side plastic cover, so I feed the wire from the wall-wart into the hole on the left and then it connects to the pigtail connector on the LED strip. There is enough clearance so you can re-install the left side cover and it does not crimp the wire. Then you plug in the wall-wart and bingo you have a full width daylight balanced LED strip all the way across your printer.
Pretty sure this can be made to work with just about any printer for $16.26.
Roland SP-540V printer with 70 inches of daylight balanced LED's installed under front top cove.jpg61.3 KB · Views: 317
