Need Help A3+ UV Epson Dx8 Head Problem print
ScriptMan
Hello.im new here and i hope someone will help me.
I got a A3+ UV Printer from china company and i have problems with print.pls check the images anyone can help me to fix this.
Im using the software Wellprint XP and for RIP UltraPrint
Any calibration tutorial or print files.will help me
CMYKENGINEERING
It looks like at least one of your problems is that you are printing too high. The fuzziness around the edges is a sign that the nozzles' focal point is higher than your substrate.
ScriptMan
Thank you. yes it fixed. now i print on 2mm and quality fixed. I think holding glass is not at the same level in all corners how i can fix it to be the same on all corners.
kamada
Hi, sometimes it could be a problem with ink fluidity, meanning that if the printer was in a cool place over night (for example) it would print like in the photo. You will have to wait severall hours after your print will be ok.
CMYKENGINEERING
You should make sure that the glass is level at all corners before modifying anything. If you have a micrometer, measure the four corners. I don't have much experience with these types of printers, so I don't know what kinds of things go wrong.
Troy Owen
Thank you. yes it fixed. now i print on 2mm and quality fixed. I think holding glass is not at the same level in all corners how I can fix it to be the same on all corners.
Wow, guy I was having the same problem with my A1 form China. It never happened before and started.
My manual says if you see it change the cartridges. It only has overspray on 3 sides and it has nothing to do with height.
It's as low as it goes, I think I clogged parts of the head, so it sprays slanted.
When I do test prints they are shabby looking compared to ones from 2 months ago.
Are you sure all you did was make the plate closer?? BTW, can you tell me who made yours?
Hon Alben
Hi friend
May you help me to get this Software please [HASHTAG]#WellPrint[/HASHTAG], i lost my CD of my printer
Please help me
