accidently over wrote a file!!!
player
It used to create .bak files that you could rename .scv and open. Try searching for your file name.* The .* means search for everything.
SignMeUpGraphics
Super Active Member
If you're using Windows, you might be able to look into the Previous Versions tab (right click in the folder the file sits in, then go to Properties).
If it's turned on and you're lucky enough, there might be a recent copy in there you can restore.
