ACM OUTSIDE
enes sonmez
i saw a sign with Aluminum Composite backing when we are removing it. i have never used even that material is half price of .40 Aluminum itself.
Also people are making monument signs from ACM materials. what is the disadvantages of using it outside ?
signheremd
Aluminum Composite is very durable for exterior use. It comes in different thicknesses: as a 3mm it is a great material to go on a wall or over a wooden face, but 3mm is too thin to withstand wind unsupported (like when used between two posts); 6mm or thicker will do much better between posts - but keep in mind the core is plastic, therefore somewhat soft. Another weakness is it can dent easily. But the advantages far outweigh these two considerations. It looks sharp, can be bent to conform to shapes, is durable, long lasting and rot proof.
brdesign
ACM is my go to material for outdoor sign panels, I haven't made an MDO sign in years. I don't think it's very common for constructing monument signs.
It costs much less cause it has 2 pieces of aluminum about .007" to .010" sandwiched around a piece or exterior grade plastic, so it only has 1/2 the aluminum in it. However, it is strong.
bob
There isn't any downside worth worrying about. ACM is cheap, strong, and will probably outlast the next ice age. You can cut it and drill it just like it was wood and any drop is great for making jigs. If you're into that.
Now........ whodathunk ?? So hard to believe you have an EX. Sorry to hear that :omg:
Aaron Hunter
Only issue I've ever had was due to our vendor not realizing they gave us interior grade. Other than that, it's been our go to especially for routed signs as we can rout it with the Colex's 3.5 HP spindle.
JBurton
Signtologist
ACM backs are not UL compliant for use in an electrical enclosure, unless you buy acm that costs more than 063 aluminum in the first place. If you are buying channel letters with acm backs from a wholesaler, they likely are lying to the UL inspector, ask them for a breakdown of components for your own UL records and watch them panic.
Source: I make UL approved signs, and I'm cheap enough to want to use acm.
Scotchbrite
No comment
Some of the brush aluminum ACM finishes like the one pictured are not outdoor rated.
We've had some white ACM panels start discoloring to a brownish tinge after 5 years or so.
Aaron Hunter
Out of curiosity, since I've never used ACM as channel letter backs (063 or 080), does ETL allow this?
enes sonmez
thanks for everyone but what if we use the ACM to make a 6ft x 30ft Aluminum box with 2" depth. I was gonna outsource this project but the guy told me that he can do it with ACM and the customer is nationwide franchised so did not want to take risk.
Texas_Signmaker
Very Active Signmaker
So you've never heard of ACM panels and you want to make a "box" out of it instead of 040? I'm loosing count of all the red flags here. Just keep outsourcing.
JBurton
Signtologist
Couldn't say what ETL allows, but assuming they are as stringent as UL, they will likely not allow most ACM's to be used as an electrical enclosure. Even passing insulated secondary power through a piece of ACM requires a non conductive bushing.
DL Signs
Never go against the family
No, don't do that. ACM is a sign face panel for printing/ mounting vinyl to, you can even paint on it. It's durable, decorative, long lasting, and strong, but not "structure strength" strong. Plus with the plastic core, heat from any electronics & lighting could affect it, not worth all the risks. Use aluminum for the enclosure.
