Add Setup without Devices
brezelking
Hi,
i have installed Flexisign-PRO 7.5 and want to connect to the cutter P-CUT 630.
The problem ist that the cutter is working not everytime, but sometimes. We tried to install the latest driver for the USB to serial-Adapter and also tried to get it running with an older driver. Sometimes we can cut perfectly, but at most time we cannot use the cutter because he´s not there. If we try to reinstall the driver and we start the Production Manager, we can see the "Add Setup"-Dialog _without_ any printers/cutters.
I don´t no if this is a problem with my notebook or rather a problem of the Production Manager or maybe of the usb-hardware (driver/port/cable).
We run Windows XP SP2 on a Lenovo X41-Tablet-PC.
In FlexiSign we have already disabled "Use Production Manager over TCP/IP".
Is there any tutorial how to connect this cutter to a notebook with USB to serial or just with Serial-Cable?
We look forward to get answers.
Thanks a lot.
John
iSign
my guess would be that you have a cheap USB/serial adaptor, made for use with a PDA, not a plotter.
Some USB/serial adaptors have been know to work, but for running plotters.... most of them won't work.
"high speed communication" is one of the factors to look for.
