Adobe to Corel
myront
CorelDRAW is best
Under the Pathfinder Toolbox Unite means to unite two shapes i.e. weld them in corel terms. No option to create a path around the two shapes or even one single shape?
WildWestDesigns
yes. Offset Path at with offset at 0. No fill & stroke to red.
Object>Path>Offset Path
Again, you can automate it with the Actions as well. In fact, when I mentioned you could click a box to have the action stop to where you enter the size you want, this is the action that I was thinking of as I use it a lot.
myront
CorelDRAW is best
That's what I'm trying to record.
When you create an Offset Path it should be just that, an "unfilled" path. A simple and separate path around the shape with a Stroke only. Action records setting the stroke just fine but will not record a no fill.
WildWestDesigns
For some reason, I'm not able to post a screenshot, keeps on telling me that it's an invalid file.
In your Action sequence, do you have this line: "Set Color swap fill and stroke"? I applied a different color to the fill and then swapped that with the previous stroke which was no stroke.
myront
CorelDRAW is best
yeah, I'm getting the same message.
▼Create Boundary
______________________
▼Offset Path
Offset: 0 pt
Miter Limit: 4
Line Join: Miter
▼Swatches
Apply Swatch: [None]
▼Swatches
Apply Swatch: CMYK Red
WildWestDesigns
▼Create Boundary
▼Offset Path
Offset: 0 pt
Miter Limit: 4
Line Join: Miter
▼Swatches
▼Swatches
I saw another message were others are having probs, so it's gotta be a system thing.
I'm not seeing "swap" and I think that's the key thing.
Make sure you have no stroke to begin with. Do your offset, apply the color to the fill of the offset and then swap your fill for you stroke.
That's the only think that I can think of. In my world (embroidery design), I keep the fill there and don't need a stroke, so this isn't an issue for me.
myront
CorelDRAW is best
getting closer. I should be left with two shapes after playing the action. The original shape and the newly created shape with the red stroke and no fill. All I get now is the red stroke shape. The original gets deleted.
WildWestDesigns
That's a new one on me, unless a delete got recorded or the copy/paste etc didn't get recorded etc.
That would have to be something that I would have to see how the process went to know for sure.
myront
CorelDRAW is best
got it. What a pia for such a simple task. Corel has it built in already as with a whole lot of other things.
