Anyone Know This............. ??
This panel is about 1/4" thick and has radius corners. It measures out at 6" x 12". It fits into this bracket or holder piece.
The building management wants some new ones exactly like them and has some to replace and it's all under new management and they haven't a clue as to where to find them.
Any ideas or clue as to where to look or who to ask ??
I've never seen these and looked on a few sites, but evidently..... not the right one, yet.
:thankyou: Gino
FireSprint.com
Trade Only Screen & Digital Sign Printing
Looks like a license plate. I wonder if you couldn't get them cut by someone who regularly does them.
No, it's raised copy and ADA braille on it.
Sorry, I thought that was a given. Guess I should've mentioned the ADA part.
Billct2
Scott would be a good place to look.
If you need just the plates you could have them fabricated by someone who
does ADA, using engraving stock. I had some custom made that were a lot like these.
Except the braille was clear dots set in the background. The place did them on a Gerber router.
Rick
Looks kinda like some older Apco or Scott. I wonder why they didn't just do the #306 in braille, all that other copy is ADA overkill...
Richard G
Gino, you can talk to Dave at Classic Architectural 800-238-4444. he is across the street from me and has been selling these ADA signs for years around the country.
CanuckSigns
check with an engraving shop, the frames are a stock item at all the suppliers we use, the sign face looks to be just engraving stock with raised tactile letters and braille. There is a merchant member here who does engraving (C&C i think?) they should be able to make these for you.
W
www.esigns.com
Guest
Hi Gino, if you havent found a solution let me know and I can recommend a few ada sign suppliers. as mentioned the frames are a common stock item and it looks like someone got WAY oversold on the requirements of ADA signs...
dan@esigns.com
