Calling all PhotoShop experts.
threeputt
Can't figure this one out.
I'm using CS5. Client has sent me a large bitmap file, 11"x17" at 800 dpi.
After opening it in PS, I find that I can't do anything with it. When I select a tool and mouse over the image, I get a
circle/slash icon.
I can't even create a duplicate layer. Tried saving it as a .tif file with the same result.
I haven't encountered this before.
What am I doing wrong here?
Any help is greatly appreciated.
MikeD
Did you get it?
could be as simple as the layer being locked?
maybe the doc itself is "locked from editing?"
Maybe more RAM needs to be allocated?
Hope you are able to get it figured out.
SignBurst PCs
See if it is in "Indexed Color" mode.
Image > Mode
If it is, change it to RGB (preferably) and you should be able to edit it.
threeputt
This is pretty maddening. Can't change channel or image mode. Most items are greyed out/not available.
Weird, huh?
TammieH
Also, you can use the Rectangular Marquee, draw a box around the complete image and copy/ paste into a new file...but either way works
