Cleaning bottom rollers on s2
bdw99
What do you guys use to clean the bottom roller? If though of using a wire brush but would that damage the grit on the rollers?
DL Signs
Never go against the family
You can get cleaning brushes from any hardware store, cheapest at Harbor Freight. They look like toothbrushes, but stiffer, come in nylon, brass and stainless bristles. They work great for grit rollers & such, if they're too gunked up for the nylon one, you just step up to the brass one. I use alcohol and these...
FrankW
You should use a self-adhesive tape, put it with the adhesive side on the roller. I would not use metal brushes, it is very expensive to replace the rollers if you damage the surface, better live with dirt.
DL Signs
Absolutely for the rubber roller, but for the metal grit rollers (which I assume he's talking about by referring to the "lower" roller) brushes won't cause any damage.
