Need Help Color not printing, Mimaki JV-33-130.
222creations
I started having problems with my blue. stopped one day then started to work for the next few prints, now the only way to get it to print is to manually flush the head. After flushing it will work to the next print and i can immediately print the same image and the blue will not work.
Change your dampers and the little claw piece that connects it to the ink line along with the o-ring that seals that connection. If that doesn't do the trick, change the ink line and o-ring connection for that channel. These machines are on the older side and tend to have leaky lines and connections.
