Corel Fill
captainron19
in Corel Draw..... I have a circular image. File format in Corel Paint and also PNG so there is no square box around it background is transparent. I need to fill an object in corel draw with this circular pattern but I want the circles of the fill to overlap and completely fill the area in. Each time I tried to do it with the "Fill with Texture" and I load the image, it fills it but tiles the circles next to eachother so there is white showing. Any idea on what I can do?
captainron19
Yeah I guess that was pretty vague. Here is a screen shot that my describe it better on what I am looking to do. I did try a multiple copy and paste of the swirl image and placed them all around the border of the image I am looking to fill then power clipped it in but it made the file size HUGE and if one circle was off it was a pain to edit
neato
Is this for print or just for presentation? If it's just presentation, just reduce the resolution of the bitmap.
The other option is to just create a circle and imitate the fill with a gradient, then copy and place how you want it.
I wouldn't do either though. I would just find an engine turned gold bitmap texture and use that instead of individual circles.
I use Corel everyday, all day, but I don't know all the neat little tricks and secrets it holds. Maybe someone else will have a better option for you.
captainron19
Yes it is for print on vinyl...... Here is an idea of the effect I was able to re-produce by using the power clip function but like I said it made the file huge in size
captainron19
Yes that was much better....... got a good effect with that idea and the file size is now only 20MB when before with the power clip was almost 200mb
THANKS !
