Coreldraw X8 Crashing At Launch Win10 Pro
Discussion in 'Corel' started by Bobby H, Apr 24, 2017.
  1. Bobby H
    Bobby H Very Active Member
    1,375
    1
    38
    Feb 4, 2005
    Lawton, OK
    Is anyone else having problems lately with CorelDRAW X8? This morning I've tried launching the application numerous times and it keeps crashing while loading. The application was working just fine on Friday. I've restarted my PC a couple different times but am getting the same result. I'm not sure if uninstalling/reinstalling will help, but that looks like perhaps the next step. BTW, my PC is running Win 10 Pro.
    I've tried to check the forum at http://community.coreldraw.com/ to see if there are any similar complaints. But the forum page won't load at all. It just keeps timing out. Is anyone else seeing that same issue?
    It's kind of odd version X8 had only one maintenance patch since it was released last year. Now Corel wants $199 for a really paltry upgrade for CorelDRAW 2017 barely one year after X8 was released.
  2. WildWestDesigns
    WildWestDesigns Merchant Member
    4,642
    31
    48
    Sep 27, 2010
    Mid TN
    I'm sorry I can't help with the issues as I don't run Corel, but I thought I would mention that based on the YouTube video that Corel put out for the 2017 version, the yearly release is the new planned release schedule.
  3. Bobby H
    1,375
    1
    38
    Feb 4, 2005
    Lawton, OK
    Once I was able to finally get into the CorelDRAW community forum it turns out there is some kind of new bug causing the crash at launch. There is discussion of it in this thread, including a registry fix that allows CorelDRAW X8 to launch.
    Coreldraw x8 has stopped working - CorelDRAW Graphics Suite X8 - CorelDRAW Graphics Suite X8 - CorelDRAW Community
    After downloading the CDGS_fix.txt file, renaming it with the .reg suffix and applying it to the registry it should fix launch issues with CorelDRAW X8 and CorelDRAW 2017. The downside is you'll have to sign into your CorelDRAW account again when the program launches.
  4. timgo
    timgo Graphics Designer
    117
    3
    18
    Aug 20, 2016
    Delft
    Install CorelDraw software again.
  5. Bobby H
    1,375
    1
    38
    Feb 4, 2005
    Lawton, OK
    Reinstalling CorelDRAW X8 will not solve that problem. If you visit the discussion thread at the CorelDRAW community forum you'll see how others have tried uninstalling and reinstalling to no avail. Running the registry hack the folks from Corel provided will solve the problem.
  6. signsbydale
    signsbydale Major Contributor
    I'm having the same problem with Quick Books. An error message comes up asking for what I was doing to report the error to Intuit. If I fill it out and send it, the program shuts down. If I click on the QB window instead, I can use the program normally.
  7. Sig's Signs
    Sig's Signs New Member
    1
    Apr 3, 2017
    NC
    That fixed my problem as I had the same issue yesterday as well.
  8. matthewota
    matthewota Electrical/Architectural Sign Designer
    My Corel crashes sometimes when I do a drag and drop copy operation. All I can do is hit Ctrl S a lot....
  9. Nick Denny
    Nick Denny New Member
    18
    8
    3
    Feb 23, 2017
    Wichita, KS
    I just upgraded to X8 last month. Haven't had any issues so far. I had X5 which was crashing all the time. Thanks for posting, I will keep an eye out for this.
  10. Bobby H
    1,375
    1
    38
    Feb 4, 2005
    Lawton, OK
    Maybe it's just the computers I use, but I wish CorelDRAW X8 wasn't so laggy when launching, opening files and scrolling through the font menu. Sometimes I have to drag files into X8 from the Windows Explorer window because the program occasionally locks up when opening files in the file>open dialog box. Version X6 was the last version that worked pretty responsively in all aspects.
  11. Bobby H
    1,375
    1
    38
    Feb 4, 2005
    Lawton, OK
    Well, my CorelDRAW X8 installation started crashing upon launch yet again this morning, rendering the previous registry fix worthless. Thankfully Corel posted a new "hot fix" patch (cdgs-hf1.exe) for both X8 and CDR 2017 on their website. Hopefully this solution will be more permanent.
  12. Because of problems I had running Windows 10 I switched back to Windows 8 and solved most of my problems.
    I must admit some of my problems were not really Windows 10 problems but because it's new I could not find updates for my scanners and other equipment.
    When I went shopping for a new scanner at Best Buy the salesman asked me which version of Windows I had and when I said 10 he told me that none of the scanners in the store were compatible with windows 10
    When I did a little more research I found that many companies do not have updated drivers that will work with 10
    I took the easy way out and went back to Windows 8 and now everything works fine again.
    The moral to the story is it's not always easy when you decide to upgrade your software.
    Jim
  13. WildWestDesigns
    4,642
    31
    48
    Sep 27, 2010
    Mid TN
    I've always subscribed to the theory that it isn't always best to be "bleeding edge" when dealing with "mission critical" applications, hardware etc. There are legitimate reasons why enterprise users (not necessarily Windows Enterprise users, but business (enterprise) users) do not migrate as soon as the normal home user would.
    "Teething pain" is to be expected. I used to use an OS that would go EOL every 13 months on average (Fedora) and that's hell on a business.
    • Agree Agree x 1
