corners
craigco
I want to make .5" radius corners. How do you to that? I know how to make corners round, but do not know how to adjust their size to what i want.
Any clues?
Thanks,
Craig
Bogie
Pies are square.
A half-inch radius means you're cutting a 1" circle. Only not all of the circle.
Easy tip: Exacto around a quarter, or if you're really feeling like a high roller, use a Susan B...
craigco
For example: i have one of those corner rounders that has a .5" die in it.
I want to add a border to a car magnet. How do i get the border to be the same size as the .5" rounded corner.
Columbia Signs
Not sure I understand what you are asking, but try using the interactive Contour Tool. That will add a border around your .5 corner. Make sure you have the tool selected to outside (or inside) and only 1 step.
dclet
In coreldraw x3
go to Window - Dockers - Fillet/Scallop/Chamfer
choose your corner node, or all 4 nodes
choose "fillet" from drop menu
adjust setting to .5 click apply
you can then contour that to create a border....
*note
Any rectangle you make using the rectangle tool you'll have to convert to curves first (ctrl - Q)
craigco
yea, i have that. But i need to know how to have the .5" corner already there to contour around.
It's easy to make a rounded corner. But how do you know what size it is?
Another example, just talked to someone about getting some aluminum cut. They asked "Is 3/4 radius corner ok?"
I need to know how to draw a rectangle with 3/4" radius corners, so I can see if it is ok.
300mphGraphics
This might be what you're looking for..
Columbia Signs
In the tool box flyout select the one right below the "A" text botton. Make it fly out by clicking the little black triangle in the bottom corner. Select the one that looks like many square boxes inside boxes. That is the Contour Tool you need.
WhiskeyDreamer
Professional Snow Ninja
look at the pick.............measure from where the two lines meet out to the outside edge of the sign....that is your radius..
S
Sign-Man Signs
Guest
Flexi it's simple. Corel, no idea. I understand your are trying to match your corner radius machine. We just did the trial and error deal on paper till we matched it. We just keep it on file when we do corner radius mag's.
Columbia Signs
Let me see if I understand what you are trying to do....
You have made your rounded corners.... yes / no? You now want to contour a line around them? So when you are done you will have your .5 radious coners and another line that goes around them? Corel 12 has that tool. I remember using it back in ver 9.
Columbia Signs
If all you're trying to do is make a .5 radious corner. Draw a box, use the node tool and slide one of the nodes. All 4 coners nodes will automaticly radious.
