cutting from corel
msenjur
Hello!
i have format whole pc, and started over again. But i cant find old program for cutting (eurocut 3.0) that i used before.
So, i tryed to cut direct from corel draw to Roland camm-1, pnc 1100.
I managed to get the cutter working and everything, im just having problems with page orientation. I just cant set it up, that the cutter would cut from same position as shown in Print preview.
Can anybody help?
Thanks for reply!
Techman
contact Old Paint, a member here, He invented cutting direct from corel about 20 yrs ago. He knows all the drivers, and connections to make it cut direct from corel.
OldPaint
you need to set up the orientation in the roland driver............and set the page in corel BOTH THE SAME. when you open printer setup in corel after you have selected the roland as your printer.......you will see a page on it and the letter A, should be laying on its side.. now in corel page setup you should be LANDSCAPE ......i have a page set in corel as as plotter 23.50 X110.00 i do all my work on. when you hit print preview it will show it exactly as it will cut it.
OldPaint
dos bey don ya
