Edge prints along the bottom continually dropping out
gabagoo
Take a look at this photo. It is occuring just along the bottom "0"'s only. I just cleaned the head and it is still doing it. Duracoat cartridges.
Any idea how to stop this?
Billct2
If it was just the black I'd say it was the cartridge, but you're getting that other problem with the yellow? They look like
two different issues.
gabagoo
No the yellow is the vinyl I print on..... I think it might be the cartridge, although I am not sure how to fix it
Caitlin
Has it been doing this for a while? Maybe it's just a section of the foil and you just need to get past it... I sometimes have foils leave lines or something but clears up after a couple feet.
gabagoo
warning...dont hit the reply to thread after you have replied to thread...it erases everything...doh
anyways it is odd that it did this on and off throughout that job, but not at all when i switched to yellow refective
gabagoo
no I have seen this many times over the years, but never have figured out why it happens. I cleaned the heads as well and still does it. It might be a bad foil where the lower edge may be trying to curl up. but too hard to figure out.
