Epson 80600 Light magenta nozzle clogged on Head 1
JJure
Hi. I have a problem with LM only on head 1. All the sudden the pattern began uncomplete (pic). I did several manual head cleanings, and few light, medium and heavy nozzle cleanings on LM/LC channel.
Nothing really changed except little difference in those patterns.
Didn’t try head wash option for LM/LC yet.
Any suggestion?
Regards,
Jure
PhantomSteve
In my experience, the head is starting to go.
Which means a head replacement.
How old is the printer?
We have a 40600 and we are about to install our 4th print head in 5 years — which is really bad — but South Africa's crap electricity supply is probably partially to blame as the printer only works about 4 hours a day if averaged out.
Sometimes you get lucky, sometimes you don't.
V. V.
Inkjet printing guru
Agreed.
Lifetime cycle is the head is about 20k.sqm or 1.5y
JJure
Printer is approx. 3 years old (17.1.2020), 6.600 sqm if LFP accounting tool is corect.
Till now everything works perfect, 100% nozzle check. This happend from nothing.
V. V.
Had absolutely the same situation recently in my 30610. Lost one C and one M within two weeks so replaced the head in the end.
PhantomSteve
That's how a head failure looks.
Perfect — then a blocked nozzle — then 2 or 3 — then more (especially if the same nozzles remain blocked).
And you think it can't be the head — you hope it's not the head.
You look for other solutions — you find people who say it isn't the head.
You are hopeful.
You try everything.
And in the end, it is the head — and all you've done is waste your time and print production time.
I've been there — many times.
StickerGuy83
I was told from my equipment supplier than the heads in my s80600L would last 2-3 years at the volume I print (6-8 hours per day). Within 10 months I started getting horizontal banding in a couple channels. Heavy cleaning cleared it up and it would print 5-6 feet, then start banding again. Luckily at that time, it was still under warranty. Decision One came and replaced both heads, capping station and dampers. A mere 6k I avoided. When the warranty was up I purchased the 1 year warranty and I will every year moving forward until this unit gets replaced (hopefully not for another 5-6 years). That warranty comes in clutch when things like this happen. No questions -- They over night the parts and a tech shows up a couple hours after the shipping shows it was delivered. In and out in a couple hours. Worth the peace of mind.
