F-2 fuse question.
Jim Hill
The F-2 fuse on the SP-300V is 1.6 amp.
My question is an 1.6 amp fuse from an auto parts store the same being that it's only for 12 volts?
or am I looking for a 1.6 amp fuse for 120 volts?
The fuse is blown because when the new print head did not print I started checking the ribbon cables that go to the head and the top part of the cable was not plugged in all the way on top so without thinking and turning off the power first I unplugged it and then plugged it back in which blew the fuse.
Jim
crny1
Is the original blown fuse a glass fuse or white ceramic? If it is ceramic then its probably a FAST blow fuse. Glass ones are not considered fast blow and will more than likely take something else out on the board if it blows again.
Jim Hill
The original Roland fuse was a ceramic fuse.
I have a Roland tech coming out to change the original fuse. I have a new Roland ceramic fuse.
I am still trying to figure out the error message which reads "Temperature is too low"
Hopefully the tech will be able to figure out what the error message is and how to fix it.
Thanks Jim
