From Corelx3 To Versaworks Rip Failure
Discussion in 'Corel' started by Bobas Kalobas, Apr 28, 2017.
  1. Bobas Kalobas
    Bobas Kalobas New Member
    22
    Feb 19, 2008
    Baxley
    Hello,
    Recently and suddenly, my files will not rip. I export .eps from Corelx3 to Versaworks software and the window pops up "Versaworks application has stopped working, check online for a solution and close the program.etc"
    I am using Win7 professional, plenty of Ram and an i7 processor.
  2. Bobas Kalobas
    22
    Feb 19, 2008
    Baxley
    Is there anyone that can help? Thanks
  3. Roto
    Roto Member
    182
    1
    18
    Jul 19, 2011
    Australia
    Try using PDF to go to the RIP
    • Like Like x 1
  4. Bobby H
    Bobby H Very Active Member
    1,375
    1
    38
    Feb 4, 2005
    Lawton, OK
    Some trouble shooting stuff: Make sure you have the latest updates of VersaWorks installed. Going the PDF route is worth a try. Normally anything I design in CorelDRAW and send to VersaWorks is usually going through Adobe Illustrator first to get the colors just right.
    • Like Like x 1
  5. Bobas Kalobas
    22
    Feb 19, 2008
    Baxley
    Thank you sir for your help But, will the .pdf still allow me to have a CUTLINE? I use .EPS because it is the only one that I can print/cutContour.
    I am willing to buy new design software, but would hate to see the same problem still remain.
  6. Bobas Kalobas
    22
    Feb 19, 2008
    Baxley
    I do not have AI. but, I do have the lastest Versaworks installed.. I also have the technicians baffled on this problem. They cannot figure it out.
  7. Vohaul
    Vohaul Member
    40
    Aug 12, 2013
    Calgary alberta
    Yes it does.... 99 percent of my jobs are sent from Corel as pdfs..... using Roland colours and a cut line .... no issues, aside from that transparency thing
  8. myront
    myront Active Member
    503
    29
    28
    Dec 3, 2015
    Niceville, FL
    You do know you can plot from Corel with a software plugin. We use FineCut Pro. All Cut lines and Registration Marks are set up from various workstations throughout the shop using Corel and macros. Our prints are done from a designated RIP workstation via Flexi Production Manager. We print eps,.tif and pdf
