gerber edge running vinyl too far
signgirl
Hmm first for me...set a file up with contour cut and after it prints the registration mark it slews the vinyl about 3 ft then prints the image. I've checked all the settings and they look normal.
Fred Weiss
Best guess is that you have a small object out to the left. To check, open job in Composer and press F2 to Select All. If that doesn't do it then, in Composer, select just what you want to print and use the Output Selected command (Shift +F12).
signgirl
Thanks Fred, I did check for that and made sure I grouped what I was going to rip and print. I'm running in flexi so maybe it's just a quirk. I'll give it another try in the morning
