Gerber Omega 5.0 Demo
D-Kal
Hello, Everyone
I recently acquired a Gerber Edge had one before but this one is newer but it still came with Omega 1.54 , so I been messing around with a Demo of Omega 5.0.
When I import a Illustrator AI file, I get a Grey background does any body know why?
How can I change it too white?
MaxiKyle
Under Tools>Options>Palletes+Colors
Should be able to change the background color to whatever you want.
D-Kal
Thanks I figured it out I had the wireframe option off,
No my background is white but the colors of the artwork don't show, I have a feeling am probably still doing something wrong?
J Hill Designs
wireframe won't show colors. just the 'wireframe' of the art
the 'grey' background is just fluff when in filled view mode, most likely so you can see white vinyl
D-Kal
Okay turned the wireframe off, got my colors back
But now on the bottom they changed from spot to CYMk and I went in the palette option and changed it to white but I still have a gray background :banghead:
MaxiKyle
By pressing F8 it flips between filled/wireframe. Still not sure if this is what you are after.
J Hill Designs
possibly 2 shapes on top of each other, thereby cancelling each other out, and showing the default grey
J Hill Designs
in 1.56 its tools -> options -> vinyl tab - default background color
but its default grey for a reason -- so you can see white vinyl elements
D-Kal
Thanks that makes since as it is being printed on white vinyl.
Am on Omega 5.0 Demo
How do I change back to spot colors?
J Hill Designs
since its a vector object, tools -> images -> x will do nothing, its not an image
you have to select each vector component and choose colors from your palletes to the left
D-Kal
Great that worked but my colors are to the right,
It chnage the color to the spot colors but the CYMK colors are still there with the spot color, will this effect anything?
J Hill Designs
hard to tell. Im starting to have trouble wrapping my brain around what you are trying to accomplish and/or working with
D-Kal
Sorry,
am just practicing on Omega 5.0 so I figured out how to import AI files.
And Know I imported a new file and the colors changed to CYMK,
The Gerber Spot colors are perfect for what am doing.
J Hill Designs
Sorry,
personally, I would start learning by designing within omega - get the basics down of foil selection, cut/not cut, knockout, overprint, etc
before trying to import and do all that
