GIF with transparent background?
Colin
I used to be able to make the b/g transparent upon exporting as a GIF in v12, but it doesn't seem to be working in X5. What am I missing? I have "Transparency" checked.
Roto
Seems to be working here using X5
Roto
GAC05
Quit buggin' me
Working here too Colin.
Are you exporting out of Draw or PhotoPaint?
I used the default "Export for Web" out of draw and it set the white background to transparent without changing any options.
wayne k
guam usa
Colin
Draw.
I tried that, as well as the regular old "Export".
When I then Import the file into CorelDraw, it isn't transparent.
Colin
I figured it out. The fill of the box I draw around the text/graphic needs to have a "no-fill" as opposed to white or a color.
Thanks.
FireSprint.com
Trade Only Screen & Digital Sign Printing
I was just going to suggest that. I had the same problem a couple of weeks ago. Finally figured it out in a dream at 3am.
Colin
In 12 I used to be able to give the box a fill of color, and then select that color with the eydropper tool in the Export window, and make that transparent. That doesn't seem to work in X5, unless I'm missing some little step.
