Heater voltage setting error.
spudcity
This message just started popping up recently (Heater Voltage Setting Error). I haven't changed any of my settings on the printer, other than increasing the temp for a different profile. I've lowered the temps and it is still happening. I've checked to see if the setting on the voltage switch has changed, and it is still at 115V.
Any ideas on this?
spudcity
The room and the printer are too cold.
Thanks Mike, haven't had the problem since I took the surge protector out of the middle. I'll keep that in mind in case it happens again. The room is right around 68 all the time and usually gets a little warmer when I am using the machine, so I wouldn't think this would be the problem? Also, it has been happening after using the machine for a while with the heaters on.
