Help. Looking for z motor gerber dimension 200E
teddc671
Help...looking if anyone on here has an x axis motor type M063-LS-518E for a very old Gerber Dimension 200E cnc router for sale or can direct me to one. Thank you.
nssignguy
I have an old Gerber 200 that I can sell parts on if you need. Let me know.
teddc671
Here's a few pics
JBurton
Signtologist
These are simple to replace, you just need those values on the label to match a new motor. Brand doesn't matter, exceeding the hold value of 150oz/in is fine, but voltage, amperage, and steps per revolution need to match. You'll also want to make sure your new one has a long enough shaft of the same diameter, but otherwise it should just be a nema 23 motor.
teddc671
Thank you..would you happen to recommend or lead me to the right place that has the for sell? I appreciate your help.
Vassago
Looks like a standard stepper. Just measure the mount to tell you what size, then find one with the same shaft details. Should be either 4,6 or 8 wires depending on the type, but they all connect to 4
JBurton
Signtologist
I'd buy the one nssignguy has on hand, the amount of time chasing down the appropriate wiring scheme alone would be well worth the difference in cost between whatever he's selling and the cheapest equivalent.
