Need Help How Eliminate the inks white and metallic Vs540i
wayaman
Waya
Hello Guys, Some body knows how change from E-SOL MAX2 CMYKLmLcWMT to E-SOl Max2 4C : E-SOL MAX2 CMYK ? i want to change the ink but don't know how change or eliminated white ink and metallic ink.
i try to change from the service menu but only have
PIGMENT 4COLOR: PIGMENT
E-SOL MAX2 WMT: E-SOL MAX2 CMYKLmLcWMT
E-SOL MAX3 WMT: E-SOL MAX3 CMYKLmLcWMT
UNKNOWN: Ink Type not specified
Don't have another mode, i guess that i need make a factory reset or something like that.
Service menu Ink type
Boudica
Not familiar with your machine, but with our Epson we put the cleaning cartridge in where the white/silver would go.
wayaman
Waya
Ok Fixed
This the process.
1 Turn on the machine in the service mode ( press the keys Left + Down + Right at the same time and then turn on the machine sub power button)
2 - HEAD WASH Perform HEAD WASH. 8 SL-CL cartridges are necessary to do it.
How Activate Resetting ink mode setting
3 - SERVICE MENU > SUB MENU > CHANGE INK TYPE, set it to [UNKNOWN].
4 - SYSTEM SWITCH > PAGE7, set it to [10000000].
5 - RESET INK MODE appears in SUB MENU, Press ENTER key in RESET INK MODE. The cleared
6 - SYSTEM SWITCH > PAGE 7, set it back to (00000000) to hide RESET INK MODE
7 - Turn off the printer
8 - Turn on the printer and set the ink mode
PIGMENT 4COLOR: PIGMENT CMYK
E-SOI Max2 4C: E-SOL MAX2 CMYK
E-SOL MAX2 7C: E-SOL MAX2 CMYKLmLcLk
E-SOL MAX2 LKW: E-SOL MAX2 CMYKLmLcLkW
E-SOI MAX2 LKMT: E-SOL MAX2 CMYKLmLcLkMT
9 - Fill Ink ( this process take 10 minutes approximate )
