Need Help How to connect a roland Xc-540 with cat5 crossover cables (I don't have internet) thanks!
HCC
I don't have Internet and I try to install versaworks 2.2 over crossover cable direct computer to printer. I really appreciate anyone's help.
(Computer has windows 7)
Tizz
You can connect your pc directly to your roland using just a LAN cable. I have been printing for the last month connected directly to my SP540. You just need to set your IP and permissions on your pc and allow this through your firewall.
HCC
Hi tizz, appreciate your help
could you guide me to setup I test ping from the computer to printer ip and come 0 lost the communication is working
HCC
I SET THE IP IN MY COMPUTER FINAL .125 AND IN THE PRINTER .126
SUB COMPUTER 255.255.0.0 SUB ON PRINTER 255.255.0.126
GATEWAY IN BOTH 0.0.0.0
I HAVE 3 JOBS TO FINISH IF ANYONE CAN HELP ME I APPRECIATE.
THANKS!
particleman
Assuming you have a cross over you need to create your own lan. In the olden days this was something we all had to do, now we have routers and DHCP.
You'll need to assign the IP at both the printer and the computer. The IP has to be on the same subnet and range.
This video explains the process, instead of two computers you'll setup a static IP on the printer (2nd computer)
HCC
Subnet for both should match. 255.255.255.0 should be fine for direct connection.
Thank you
Thank's.
HCC
I got the print connected and received this error the versaworks stop
my computer running windows 7 premium
