How to get DX4 head Rank
Biggermens
Any one know how to get the head rank from a head that has no label on it ???
i have a few heads and the decals got washed off :((
Biggermens
the head ranks are stored in the machine memory. can only be access via service mode.
Hi Thanks For the reply
I can find the head rank in the service mode but i got all the heads mixed up when i was cleaning everything.
Like Perfectpdf said i guess it don't mater to much ??
davyde
There is no way to get rank from heads if you mixed them up. The rank is a calibration number for correct firing pattern. After market heads or wrong ranks will show a "incorrect head installed" message and will attempt to clean more often (past experience). Running machine in service mode all the time will avoid all that.
Jim Hill
I used the head ranking numbers that came with my new head. They were located on the outside of the plastic case that protected the head in shipping.
I have never tried installing a New print head without using the head ranking numbers but I do know some people who do it and it appears to work which may be because the original ranking numbers are still programed into the printer.
Jim
I have installed over 100 DX4 print heads without inputting head ranks and there is absolutely no difference.
